Debian repository has errors
Michael_3421
Michael_3421 Posts: 2 ✭✭
edited August 2021 in Linux only
root@localhost # aptitude -y update
[snip]
Get: 2 https://linux.teamviewer.com/deb stable/main amd64 Packages [11.4 kB]
Err https://linux.teamviewer.com/deb stable/main amd64 Packages
 File has unexpected size (11205 != 11438). Mirror sync in progress? [IP: 52.84.70.86 443]
Hashes of expected file:
 - Filesize:11438 [weak]
 - SHA256:63812a1ac3766b349784a2d3214d2f828ccd0f0c48486d903058d60f539b937b
 - SHA1:47dbf56116a53965fd64eaa37f394d54efc3ade9 [weak]
 - MD5Sum:4108c1029f6d1e10122435e985027a07 [weak]
Release file created at: Tue, 24 Aug 2021 12:25:36 +0000
E: Some index files failed to download. They have been ignored, or old ones used instead.
root@localhost #
  • adrian_vg
    adrian_vg Posts: 2 ✭✭
    Getting the same. Seems only 32b-repo is working?
    Get:17 https://linux.teamviewer.com/deb stable/main i386 Packages [11,2 kB]
    Get:18 https://linux.teamviewer.com/deb stable/main amd64 Packages [11,4 kB]
    Err:18 https://linux.teamviewer.com/deb stable/main amd64 Packages
     File has unexpected size (11205 != 11438). Mirror sync in progress? [IP: 65.9.55.99 443]
    Fetched 11,9 kB in 3s (4 325 B/s)
    Reading package lists... Done
    E: Failed to fetch https://linux.teamviewer.com/deb/dists/stable/main/binary-amd64/Packages.gz  File has unexpected size (11205 != 11438). Mirror sync in progress? [IP: 65.9.55.99 443]
  • Natascha
    Hi @Michael_3421 @adrian_vg
    Thank you both for your comments 😊
    I already forwarded this thread to the dedicated team. Can you please check if everything is working properly again?
    Looking forward to your answer.
    Natascha 🙋‍♀️
  • Michael_3421
    @Natascha , thanks for forwarding the issue to the relevant team. The problem has been solved.
  • Natascha
    @Michael_3421 You're welcome 😊
  • adrian_vg
    Yupp, what @Michael_3421  said.
    All okay over here and thanks for the quick fix!
  • Natascha
    Thank you guys for reporting it. Happy to hear that everything is working fine.
    Have a great day ☀
  • Spurlos
    Spurlos Posts: 2 ✭✭
    The problem is back again:
    E: Failed to fetch https://linux.teamviewer.com/deb/dists/stable/main/binary-amd64/Packages.gz  File has unexpected size (4814 != 5052). Mirror sync in progress? [IP: 99.86.240.65 443]
      - Filesize:5052 [weak]
      - SHA256:53cb2e60a6cc62bfa9473be8cf49e5c66be013b6bb589f0ac462fecff0ee7931
      - SHA1:4abfb02f88010608158f2513ce31dc12b8e54f2e [weak]
      - MD5Sum:b622786749d3bda6fc1817fe2cb35930 [weak]
      Release file created at: Tue, 27 Sep 2022 06:45:22 +0000
