As the subject says I was looking for some values and the only one I was unable to find was called "IDC"
Hi @Domurso,
Thank you for your response.
In order to assist you further, please create a support ticket.
Regarding how to submit a support ticket, please check the knowledge article.
Please note that TeamViewer licensed account is required to submit a support ticket, thus please sign in with your licensed account.
Thank you in advance for your understanding and patience.
accidentally made a new post instead of responding to this one my apologies
Received a script from a tier 2 support ...
idc=''
token=''
group=''
#Uninstall TeamViewer
#Terminates TeamViewer app
echo "Stopping TeamViewer"
osascript -e 'quit app "TeamViewer_Host"'
launchctl remove com.teamviewer.Helper#Deletes configuration files.
echo "Removing TeamViewer configuration files"
rm -f /Library/PrivilegedHelperTools/com.teamviewer.Helper
rm -f /Library/Preferences/com.teamviewer*
rm -f ~/Library/Preferences/com.teamviewer*#Set working directory to /tmp
current_path=$(pwd)
cd /tmp
cp "${current_path}/choices.xml" .#Download and Install custom host
echo "Downloading and Installing custom host"
curl -O https://dl.teamviewer.com/download/version_15x/CustomDesign/Install%20TeamViewerHost-idc$idc.pkg
installer -applyChoiceChangesXML choices.xml -pkg Install%20TeamViewerHost-idc$idc.pkg -target /#This wait is to allow time for the install to finish before running the account assignment
echo "10 seconds wait before running the account assignment"
sleep 10s#Assignment
echo "Running the account assignment"
/Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment -api-token $token -group "$group" -grant-easy-access -reassign
I filled out the missing variables and the code outputted the error in the attached image... wondering how to get this to work as it would be essential in distributing Team Viewer
Thank you for contacting TeamViewer Community.
Regarding IDC, it is required to create customized module on Management Console first.
Once you created it, please kindly check the following process.
- Access to Management Console
- Go to Design & Deploy, and select the target module and click Edit.
- IDC shows on the bottom right of the pop-up screen.
Hope it would be helpful.
Best Regards.
Have you heard?! On October 21, we’re hosting TeamViewer Rise—and we want to see you there! The digital event dedicated to IT experts. Join us to hear industry leaders as they share demos, roadmaps, and real-world strategies for delivering better IT. Take part in our first annual event for Proven, ready-to-deploy…
