Is it possible to export a list of all the devices contained within the "Computers & Contacts" section thorugh either the Web Managment console or The Teamviewer managment program on windows?
Cheers guys
Hello @Tigerpie_VS and @Kfix,
Currently, it is not possible to export the computers via a function of the Management Console.
However, it is possible to do it using the TeamViewer API. Please find more information regarding this here:
1) Click on your Username on the top right corner and click Edit Profile
2) Go to Apps and click Create script token
3) Give the token a name and select the parameter Computers & Contacts with the setting View entries and click Save.
4) This will generate the token. Please copy this token and save it for later.
1) Open PowerShell ISE as administrator and type the following code and press Enter
$jsonFile = "YOURPATH\Computers export.json" $csvFile = "YOURPATH\Computers export.csv" $tvAccessToken = read-host "Please type your token " $devicesResponse = Invoke-RestMethod -Uri "https://webapi.teamviewer.com/api/v1/devices?full_list=true" -Method Get -Headers @{authorization = "Bearer $tvAccessToken"} $devicesResponse.devices | ConvertTo-Json | Out-File $jsonFile $devicesResponse.devices | Export-Csv -Path $csvFile -Delimiter ',' -NoTypeInformation
📌Note: Don't forget to replace YOURPATH with the path you want the export to be generated to.
2) It will ask you to enter your token. Please paste your token you have saved earlier and press Enter
3) You are done. The script will automatically generate the export in the folder you have selected as [YOURPATH].
This worked great to export my computers and contacts, but it did not include the passwords for each. Is there a way to export the password for each as well?
It appears that this method does not export computers which are in the newer device groups.
I used the following script and it worked like a charm :)
$jsonFile = "C:\Temp\Computers_export.json" $csvFile = "C:\Temp\Computers_export.csv" $tvAccessToken = Read-Host "Please type your token"
$devices = @() $nextPaginationToken = $null
do { $uri = "https://webapi.teamviewer.com/api/v1/devices?full_list=true" if ($nextPaginationToken) { $uri += "&nextPaginationToken=$nextPaginationToken" } $response = Invoke-RestMethod -Uri $uri -Method Get -Headers @{authorization = "Bearer $tvAccessToken"} $devices += $response.devices $nextPaginationToken = $response.nextPaginationToken } while ($nextPaginationToken)
$devices | Select-Object remotecontrol_id, device_id, alias, groupid, online_state, assigned_to, policy_id, last_seen, teamviewer_id | Export-Csv -Path $csvFile -Delimiter ',' -NoTypeInformation $devices | ConvertTo-Json | Out-File $jsonFile
The above screenshot is from excel.
Does anyone know how to get the full list of devices when you run the API? I'm only getting about 1000 of my devices when I run this command but I am getting a nextPaginationToken which I don't know how to use when I run the command.
Invoke-RestMethod -Uri /api/v1/managed/groups/{id}/devices -Method Get -Headers @{authorization = "Bearer $apikey"}
Much easier, just do a "Get-TeamViewerManagedDevice" or "Get-TeamViewerDevice".
Add-TeamViewerAssignment
Add-TeamViewerCustomization
Add-TeamViewerManagedDevice
Add-TeamViewerManager
Add-TeamViewerSsoExclusion
Add-TeamViewerUserGroupMember
Add-TeamViewerUserGroupToRole
Add-TeamViewerUserToRole
Connect-TeamViewerApi
Disconnect-TeamViewerApi
Export-TeamViewerSystemInformation
Get-TeamViewerAccount
Get-TeamViewerConnectionReport
Get-TeamViewerContact
Get-TeamViewerCustomModuleId
Get-TeamViewerEventLog
Get-TeamViewerGroup
Get-TeamViewerId
Get-TeamViewerInstallationDirectory
Get-TeamViewerLogFilePath
Get-TeamViewerManagedGroup
Get-TeamViewerManagementId
Get-TeamViewerManager
Get-TeamViewerPolicy
Get-TeamViewerPredefinedRole
Get-TeamViewerRole
Get-TeamViewerService
Get-TeamViewerSsoDomain
Get-TeamViewerSsoExclusion
Get-TeamViewerUser
Get-TeamViewerUserByRole
Get-TeamViewerUserGroup
Get-TeamViewerUserGroupByRole
Get-TeamViewerUserGroupMember
Get-TeamViewerVersion
Invoke-TeamViewerPackageDownload
Invoke-TeamViewerPing
New-TeamViewerContact
New-TeamViewerDevice
New-TeamViewerGroup
New-TeamViewerManagedGroup
New-TeamViewerPolicy
New-TeamViewerRole
New-TeamViewerUser
New-TeamViewerUserGroup
Publish-TeamViewerGroup
Remove-TeamViewerAssignment
Remove-TeamViewerContact
Remove-TeamViewerCustomization
Remove-TeamViewerDevice
Remove-TeamViewerGroup
Remove-TeamViewerManagedDevice
Remove-TeamViewerManagedDeviceManagement
Remove-TeamViewerManagedGroup
Remove-TeamViewerManager
Remove-TeamViewerPolicy
Remove-TeamviewerPolicyFromManagedDevice
Remove-TeamviewerPolicyFromManagedGroup
Remove-TeamViewerPredefinedRole
Remove-TeamViewerPSProxy
Remove-TeamViewerRole
Remove-TeamViewerSsoExclusion
Remove-TeamViewerUser
Remove-TeamViewerUserFromRole
Remove-TeamViewerUserGroup
Remove-TeamViewerUserGroupFromRole
Remove-TeamViewerUserGroupMember
Restart-TeamViewerService
Set-TeamViewerAccount
Set-TeamViewerAPIUri
Set-TeamViewerDevice
Set-TeamViewerGroup
Set-TeamViewerManagedDevice
Set-TeamViewerManagedGroup
Set-TeamViewerManager
Set-TeamViewerPolicy
Set-TeamViewerPredefinedRole
Set-TeamViewerPSProxy
Set-TeamViewerRole
Set-TeamViewerUser
Set-TeamViewerUserGroup
Start-TeamViewerService
Stop-TeamViewerService
Test-TeamViewerConnectivity
Test-TeamViewerInstallation
Unpublish-TeamViewerGroup
Could somebody please post new instructions for creating the token for exporting a device list? The interface has changed, and no longer matches the instructions above. There is no "Computers and Contacts" section in the list of permissions. Do we just use the Contacts section now?
Also, when I use the token I generated a year or so ago using the instructions above, I don't get a full list of computers. I think the migrated devices are missing.
How to find device Management, through script
Turns out I can't include links in my posts.
If you are trying to get a list of members of a Device Group rather than a Group
Change the -URI so it ends /v1/managed/groups which will list the Device Groups and their IDs.
Then change it to /v1/managed/groups/<GroupID>/devices to list the members
2023 and still no way to export a device list, I find this sad and pathetic. *bleep* has no issues exporting a device list.
Hello @mrcllnbrg,
There is no operating system restriction when using the API.
So yes, it's possible to do it on macOS.
/JeanK
Is there a way to do this on a Mac?
Hello @Marcelofs1,
Thank you for getting back with the info.
The best way to resolve your issue would be to create a support ticket.
Our engineers will be happy to help you further.
You can create a ticket here: 📩 Create support ticket
Sorry that I cannot help you more here, but my API knowledge is very basic.
Hello @JeanK
I am now totally puzzled. This script, using a token created for GROUP MANAGEMENT got me output
PS H:\> $headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add("Authorization", "Bearer XXXXXXXXXXXXXXXXX")
$response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/groups?' -Method 'GET' -Headers $headers
$response.groups | Select-Object -Property "id", "name", "shared_with" | Export-Csv "C:\Users\local folder\TV-groups.csv"
$response | ConvertTo-Json
Invoke-RestMethod : {"error":"invalid_token","error_description":"Access token is of wrong type. You need a UserToken to call this function.","error_code":2}
At line:3 char:13
+ $response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/g ...
+ CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-RestMethod], WebException
+ FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
"users": [
"id": "yyyyyyyyyy",
"name": "Kkkkk Jjjjjjj",
"permissions": "ShareOwnGroups,ManageUsers,EditFullProfile,ViewAllConnections,ViewOwnConnections,EditConnections,DeleteConnections,ManagePolicies,AssignPolicies,AcknowledgeAllAlerts,AcknowledgeOwnAlerts,ViewAllAssets,ViewOwnAssets,Edit
AllCustomModuleConfigs,EditOwnCustomModuleConfigs,ManageSettingPolicies,AssignSettingPolicies,ManageAntiMalwarePolicies,AssignAntiMalwarePolicies,AcknowledgeAllAntiMalwareThreats,AcknowledgeOwnAntiMalwareThreats,TrustedDeviceManagement,ManageBackupPolicies,A
ssignBackupPolicies,BackupViewAndAckOwnAlerts,AllowPasswordChange",
"active": true,
"log_sessions": true,
"show_comment_window": true,
"email": "abcde.fghijk@company.com",
"last_access_date": "2022-06-24T16:50:27Z",
"activated_license_id": "license#",
"activated_license_name": "Tensor Basic"
I got surprised as the GET function is for GROUP and I got the entire listing of users and the output file was blank (that makes sense as I am trying to get the Group listing).
Not sure if this does not also indicates some kind of security breach. I was not supposed to get a user list with such token right?
Marcelo
Thank you.
Yes I am using the correct token. I have no idea why such message occurs. I have even created a new token for GROUP management with same results.
I also tested on https://webapi.teamviewer.com/api/v1/docs/index#!/Group32management/Groups_Get_0 as it "generates" the command so I prevent the possibility of typos or something without success.
I thought of any typos or even some weird characters and double checked spelling. I have created a new token for Group Management but I am still getting the error below
Well, the function I am calling is GROUP on this line
$response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/groups?name=MYGROUP' -Method 'GET' -Headers $headers
Just for testing, I also used the USER token with the same string and got exactly the same error message.
Odd enough, when I run it for collecting the user list, it work perfect.
Once again, thank you for your time.
Welcome to the TeamViewer Community and sorry that no one got back to you earlier.
I asked our API master Guru and according to the error message,
it could be that the token you are using is wrong.
You need to make sure you use a user token and not a company token.
You can create a user token by clicking your user name ➜ Edit profile ➜ Apps ➜ Create script token
Looking forward to hearing from your tests!
Hello anyone. No response on that? I really couldn't get this listing.
I've been struggling for a while trying to use an API to get GROUPS information. I have managed to get the overall users script working fine and I am able to get a list of all users, however when I try to GET groups and their associated users I got some errors I couldn't find the reason.
The USERS scripts works fine and it is like that
$headers.Add("Authorization", "Bearer USER TOKEN Created")
$response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/users?full_list=true' -Method 'GET' -Headers $headers
$response.users | Select-Object -Property "name","email","last_access_date","active" | Export-Csv "C:\Users\MyUser\TV-USERSList.csv"
However when I try to run similar script for GROUPS users
$headers.Add("Authorization", "Bearer OTHER Token created for GROUPS")
$response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/groups?name=TST' -Method 'GET' -Headers $headers
$response.groups | Select-Object -Property "id", "name", "shared_with" | Export-Csv "C:\Users\MyUser\TV-groups.csv"
I got a BLANK .csv file however on the PowerShell screen I got the whole USERS listing even using a token created for GROUP management. Also, when running I got this error message
I have also tried to run using other tokens generated without success. I also tried running from the web interface from TeamViewer at https://webapi.teamviewer.com/api/v1/docs/index#!/Group32management/Groups_Get_0 without success.
I am quite sure I am missing something very basic on the groups query but I just can't see what it is.
@MCHD thanks for reaching out!
Could you let us know what you have exactly tried? Which data did you pull out in your operations?
@JeanK I don't know how old your solution is but tried it just now and I was able to dump the data I needed for our organization. Thanks!
I have tried the JeanK PS script, but it fails in my PowerScript with this:
Invoke-RestMethod : Den angivne værdi har ugyldige kontroltegn.
Parameternavn: value
At line:4 char:20
+ ... sResponse = Invoke-RestMethod -Uri "https://webapi.teamviewer.com/api ...
+ CategoryInfo : NotSpecified: (:) [Invoke-RestMethod], ArgumentException
+ FullyQualifiedErrorId : System.ArgumentException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
Export-Csv : Cannot bind argument to parameter 'InputObject' because it is null.
At line:6 char:28
+ ... e.devices | Export-Csv -Path $csvFile -Delimiter ',' -NoTypeInformati ...
+ CategoryInfo : InvalidData: (:) [Export-Csv], ParameterBindingValidationException
+ FullyQualifiedErrorId : ParameterArgumentValidationErrorNullNotAllowed,Microsoft.PowerShell.Commands.ExportCsvCommand
My PowerShell version is:
Name Value
PSVersion 5.1.19041.1320
PSEdition Desktop
PSCompatibleVersions {1.0, 2.0, 3.0, 4.0...}
BuildVersion 10.0.19041.1320
CLRVersion 4.0.30319.42000
WSManStackVersion 3.0
PSRemotingProtocolVersion 2.3
SerializationVersion 1.1.0.1
Can anyone help me here ??
Thanks, I just used the code provided above by JeanK.
I exported to both CSV and JSON, and I can see last_seen values in the JSON file. I think the difference is that there's no value for it in the first "row". I suspect the Export-Csv cmdlet ignores fields with names that aren't in the first row.
Hi @pshute,
Thank you for reaching out to the community ✨
Good questions!!
Honestly, I'm not 100% sure about this case.
So, I discussed the case with our technical support engineer @Scotty, and I confirmed the below details.
Last Seen
The last_seen value is optional and is only available if the device is assigned to the user doing the export and is currently offline. You can confirm this in the documentation here - 4.10.1
last_seen (optional): The timestamp of the last time, the device was online. Is not returned if the device is currently online. Only available if the device is assigned to the current user.
"Missing Column"
It is important to note that API's do not return columns, they return responses formatted in JSON with only the values for each response. In this case, I would assume you are using PowerShell or similar that is converting this into an array, then converting that into CSV.
The CSV conversion is making columns out of the returned data. If there was no "Last Seen" values returned, it would not make a column for this as this value would not have ever appeared in the array.
You can see how the raw responses look in our Test Center (Note you need to add the word "Bearer" before your API token).
Hope this answers your question!
Please let us know if you have further questions or concerns! 🙌
Akiho
When I used this method a few days ago, the header line in the dump was
"remotecontrol_id","device_id","alias","groupid","online_state","policy_id","assigned_to","last_seen","teamviewer_id"
Today the header line is
"remotecontrol_id","device_id","alias","groupid","online_state","policy_id","assigned_to","supported_features","teamviewer_id"
What happened to the last_seen column?
The TeamViewer API method described above worked to download all our devices, but why are some of the last_seen values blank? Some of the devices concerned have been accessed recently.
Hi @RyanMaeng,
Please find how to import the list into your Management Console in our documentation here:
Hi JeanK
How to import users with a csv file on powershell ??
This is currently not possible.
How can I add more parameters to your code?
I would like to add
"supported_features (string, optional),
last_seen (string, optional),"
Is it possible?
Indeed, the export is limited to the parameters you have mentioned.
There are currently no further parameters available such as the TeamViewer version, how long they have been online etc...
What can I export? At the moment I am limited to :
"remotecontrol_id":
"device_id": "
"alias":
"groupid":
"online_state":
"assigned_to":
"teamviewer_id":"
I would like to export more things about my devices. For example, Which version of teamviewer they are running, how long have they been online. etc.
