Teamviewer Custom Password
why is it with all the gazillion updates you do to teamviewer you change the one thing that was easy it's like the old saying goes "IF AIN'T BROKE DON'T FIX IT" I use to use a 4 digit password why this telling me the password is too weak I even put a longer password do you have write an essay of a password jesus christ something that use to be simple has now turned into a project is there a way to override that garbage message this ridiculous why update the program but messed that part up.
    Hello @Madman12,
    We decided to disable the possibility to use 4 digit password for... security reasons, obviously!
    We are sorry to hear that you liked this feature. However, we have opted for stronger security within our app and had to remove it.
