All Special characters are not working in Catalina 10.15.7 while connecting Team viewer remote
Akabar
Akabar Posts: 3 Newbie
edited January 10 in General Questions
Hi Support Team,
We are facing keyboard input typing issues in team viewer remote computers, We are using Macintosh 10.15.7 operating systems in our production systems. while connecting the systems using team viewer shift keys and special characters keys are not working. we are not able to type [email protected]#$ keys. Please help us resolve the issues asap.
AK
  • Justin
    Justin Posts: 567 Moderator
    Accepted Answer
    Hello @Akabar,
    Could you please enable the option "Send key combinations" in your remote session?
    You can find that in the TeamViewer Remote Session Toolbar that appears at the top of the screen of your session. Under Actions, you'll find that option.
    Please let me know if that solved your issue.
    Justin
    German Community Moderator
  • Justin
    Accepted Answer
    Hello @Akabar,
    Justin
  • Akabar
    Hi Justin,
    Thanks for your response.
    We have already enabled the mentioned option in our team viewer application.
    For your clarification we have mentioned our workflow details below.
    I am using windows 10 OS laptop to connect the remote host which is having Mac OS X 10.15.7 + team viewer.
    after connected the remote host via team viewer we just tried to connect another Mac system
    using screen sharing option. when we trying to login the system using screen sharing option we are facing
    keyboard input issue, as we have already mentioned in our earlier posts. we are not able to type any special
    characters, because shift keys and caps lock keys are not working.
    But we have tried the same with our internal network via screen sharing option everything is working fine.
    only we have skip the team viewer connectivity in scenario 2. So please help me to fix this issue.
    AK
