Disabling port 80 on teamviewer 12
I have an application that needs to use port 80 but teamviewer is currently using it, from what i have read you can stop teamviewer using port 80 but in the version i have i cant find the settings.
Any help would be greatly appreciated
    Hello @derilium,
    Please check this article to know how TeamViewer works regarding ports.
    There is no feature in the application that prevents the software to use port 80.
    You will need to look for a non-TeamViewer related solution.
    I hope this could help. 😊
    If not, do not hesitate to ask your questions here. 👇
  • ukmike
    ukmike Posts: 6 ✭✭
    edited October 2021
    In situations like this, I have **Third Party Product** installed on a machine and another on the affected machine. I log in to the first machine, then piggyback with **Third Party Product** to the other machine. A bit clunky but it works fine.
