GFX Card acceleration usage tester
mLipok
mLipok Posts: 781 ⭐Star⭐
edited November 2021 in Ideas Hub
Please provide some GFX Card acceleration guide and special tester, or just show us how to use external GFX terster to find out if TeamViewer will use this GFX Card, ...... and HOWTO . Guide how to check if a computer specyfication is enougth to have effective work with TeamViewer.
I think internal tester will be the best solution, that any device (Windows, Android, iOS, Linux) will have the same testing procedure and comparable results.
mLipok , AutoIt MVP
1
1 votes
Active · Last Updated
  • KDBSRV
    KDBSRV Posts: 1 Newbie
    Was this thread ever updated by Teamviewer?
  • mLipok
    I hope so.
    mLipok , AutoIt MVP
  • Esther
    Esther Posts: 4,112 Former Community Manager
    Hi there
    We moved this idea into the Ideas Hub to open it up for upvotes again.
    Please consider adding a user story into the comments if you upvote this idea to help our developer teams.
    Thanks, Esther
