GFX Card acceleration usage tester
Please provide some GFX Card acceleration guide and special tester, or just show us how to use external GFX terster to find out if TeamViewer will use this GFX Card, ...... and HOWTO . Guide how to check if a computer specyfication is enougth to have effective work with TeamViewer.
I think internal tester will be the best solution, that any device (Windows, Android, iOS, Linux) will have the same testing procedure and comparable results.
mLipok , AutoIt MVP
mLipok , AutoIt MVP
1
Was this thread ever updated by Teamviewer?
I hope so.
mLipok , AutoIt MVP0 -
Hi there
We moved this idea into the Ideas Hub to open it up for upvotes again.
Please consider adding a user story into the comments if you upvote this idea to help our developer teams.
Thanks, Esther
Former Community Manager
1
