LANCOM router and AllIP
Hello together,
I am using LANCOM routers for all my custumors. When I switched to AllIP (The german Telekom forced me to do this) I have the problem that my teamviewer session is freezing.
This behaviour only occurs when a telephone call ist active. The teamviewer session ist not killed, it only freezes. If I stop the session an restart id manually the connection is established normally (and fast) and after a few seconds....it freezes again..
Has someone the same conditions?
Thanx for your help
Best Answers
sb67pro Posts: 4
I solved it by my own:
LANCONFIG
Voice Call Manager
Extended (Erweitert)Outgoing packets preferred (Ausgehende Pakete bevorzugen) no change (keine Veränderung)
Incoming packets preferred (Eingehende Pakete bevorzugen) no change (keine Veränderung)
And I worx fine :-)
6 -
sb67pro Posts: 4
Hi Sigi:
LANCONFIG
Voice Call Manager
And everything worx fine :-)
6
Hi, I've the same Problem.. Have you got an answer for this Problem.?
Sigi
Thanks for your answer, I will test it.
Regards Sigi
