TeamViewer IoT Cloud API - Get Last Data not working
rhojn
rhojn Posts: 2 ✭✭
I'm currently working on an app that uses the TeamViewer IoT Cloud API, and one of the endpoints that the app needs to access is the "Get Last Data," but I can't seem to make it work. It's always returning a 151 error code with "Error.wrong parameters." error message even if I'm using the correct parameters based on the documentation.
  • mircea_c
    Hi @rhojn
    Could you please try with these parameters?
    /snapshot?sensors=[{"id":the_sensor_id,"metrics":[{"id":":the_metric_id","valueType":"double_or_string"}]}]
    Mircea
    Tech Support IoT
  • rhojn
    rhojn Posts: 2 ✭✭
    Hi @mircea_c, It's working now using the parameters you provided. Thanks!
