Change all host passwords
We recently picked up a client that has 20 users all at the same location and the previous IT client also uses Teamviewer and they have host setup on all workstations with a saved password.
How can we change that saved password and add all workstations to our account?  We need to remove their access to workstations and also want to be able to connect easily.  Do we have to hunt down all pc's and uninstall/reinstall teamviewer on all, or is there a registry key or file that has the password saved so we can do it all remotely?
  • Chiron
    Chiron Posts: 226 ✭✭
    You may also want to check the black and whitelist under the security tab.
Howdy, Stranger!
