TeamViewer 14.2.2558 doesn't show Monitors option. I have the same version on my Home PC and it works fine when I remote in from work. But the TeamViewer on my work PC doesn't show the "Minitors" option and I would like to see dual monitors.
No solution to this? 9/16/22 still having same problem. Posting a solution would be helpful.
I have the same problem. I have tried every kind of possibility but to no avail does an option to extend appear. I can mirror but that is all with no reference to modify viewing.
Same issue here!
Hello Alena,
You want to see the TeamViewer tool bar that doesn't show "View" option, correct?
Hi @asukumari ,
thank you for your post.
Could you please send screenshots of your TeamViewer toolbar that isn´t showing your monitors?
Please have a look at this article about how to select monitors Multi-Monitor Support for Windows
Have a nice day!
Alena
