Remote Access w/o Password.
How to insure that when accessing my work computer from the Laptop won't be interrupted by asking for the password or when the work computer is updating windows and will restart ? Is there a way to granting access to the computer as long as it's connected to the internet w/o the need to use the ID Password. Can I have a full control remotely.
Sorry if this question is naive, I'm new to TeamViewer.
    Hello @haythammohamed,
    No worries, there is no naive question here. 😊
    What you are looking for is connecting via Easy Access.
    You will find out how to set it up and how to connect here:
    Let me know if the turorials are clear enough to get you started!
    JeanK
  • haythammohamed
    haythammohamed Posts: 4 ✭✭
    Thanks for helping in solving this issue.
    The other computer (the one I need to access) has a restriction " Unattended Access " To setup unattended access, you need administrative rights.
    No any mark to select to enter the Admin rights ?
  • Glasheen
    Glasheen Posts: 5 ✭✭
    Not to miss the obvious, have you check to see if Teamviewer is set to run as admin? Depending on your OS, but basically it is right click on the short cut, open folder location, then right click, properties, shortcut tab, advanced then run as admin.
  • haythammohamed
    I did that, still asking to enter the password. I have that same account in both computers.
