Does Asset Managment from TV allow for uninstalling unwanted software
sljmpls
Posts: 2 ✭✭
IT would be really nice if you could select software you don't want in your environment and uninstall it from the machines that have it. Is this possible? If so we will probably convert the trial to paid product.
1
Hope I'm not treading on anyone's toes but I asked the same of support and was told not but here are scripts you could run.
I too would like the ability to uninstall unwanted software and also block certain software titles from being installed.
1
