Get 401 Unauthorized
I want to use the /api/v1/devices part of the API of TeamViewer. I have creates my Script Token from the portal, and I am able to use the /api/v1/ping successfully. With the Ping function, I am getting a OK 200 response.
When trying to use the /api/v1/devices, I get the following in PowerShell:
"Exception calling "GetResponse" with "0" argument(s): "The remote server returned an error: (401) Unauthorized."
This is my script:
$currentPath = Split-Path ((Get-Variable MyInvocation -Scope 0).Value).MyCommand.Path
. (Join-Path $currentPath "JSON 1.7.ps1")
$tvApiBaseUrl = "https://webapi.teamviewer.com"
$apiVersion = "v1"
$accesstoken = "XXXX-XXXXXXXXXXXXXXXXXX"
$req = [System.Net.WebRequest]::Create($tvApiBaseUrl + "/api/" + $apiVersion + "/devices")
$req.Method = "GET"
$req.Headers.Add("Authorization: Bearer $accessToken")
$res = $req.GetResponse()
$statusStr = $res.StatusCode
$statusCode = [int]$res.StatusCode
Write-Host "$statusCode $statusStr"
$resstream = $res.GetResponseStream()
$sr = new-object System.IO.StreamReader $resstream
$result = $sr.ReadToEnd()
if($statusCode -ne 200 )
Write-Host "Unexpected response code. Received content was:"
Write-Host $result
$result = $false
return $result
The script token have the following permission level:
Hi Christian,
Yes that was the issue, I did not know that you could create a user token in the user profile of the TeamViewer Login portal. That seem to have fixed the issue.
5
Hello holytoutant,
your script is generally working.
Are you using a user token?
The company token will not work with this method.Please check the "error_description" within the response body to verify what's wrong.
Christian
Team Lead Product Development (Enterprise)
Did my reply answer your question? To help others, please accept it as solution. Thanks!0 -
Hi Christian,
5
