I am deploying to a fleet of Macs and everything is working except I do not see any way to assign a password at deployment. Could this be added to the choices XML somehow or with a script?
Hi Jean,
I am getting a command not found error when running that.
Edit: Sorry everything ran fine I had an error on my end. Thank you for your help.
Thank you for updating the thread!
I'm happy to could resolve the issue yourself. 😊
Have a great day!
/JeanK
Hello @Gbaglin,
Applying Easy Access to your deployment is possible.
You need to use the following script template:
sudo /Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment -api-token <YOUR_APITOKEN> -grant-easy-access -group MyGroup
You'll find more information about how to deploy TeamViewer on macOS here:
