Can I assign a password or enable easy access during Deployment to MacOS?
Gbaglin
Gbaglin Posts: 3 ✭✭
edited March 2022 in General questions
I am deploying to a fleet of Macs and everything is working except I do not see any way to assign a password at deployment. Could this be added to the choices XML somehow or with a script?
  • Gbaglin
    Gbaglin Posts: 3 ✭✭
    edited March 2022 Answer ✓
    Hi Jean,
    I am getting a command not found error when running that.
    Edit: Sorry everything ran fine I had an error on my end. Thank you for your help.
    JeanK Posts: 6,854 Community Manager 🌍
    Hello @Gbaglin,
    Applying Easy Access to your deployment is possible.
    You need to use the following script template:
    sudo /Applications/TeamViewerHost.app/Contents/Helpers/TeamViewer_Assignment -api-token <YOUR_APITOKEN> -grant-easy-access -group MyGroup
    You'll find more information about how to deploy TeamViewer on macOS here:
    📄 Mass deployment on macOS
    /JeanK
  • Gbaglin
    Gbaglin Posts: 3 ✭✭
    Hi Jean,
    Thank you for updating the thread!
    I'm happy to could resolve the issue yourself. 😊
    Have a great day!
    /JeanK
