Install Host Configuration
I have made a host configuration and want to make it active in the msi but can't manage this with version 15
I use the following command for this
msiexec /i "TeamViewer_Host.msi" /qn APITOKEN=xxxxx-xxxxxxxxxxxxx CUSTOMCONFIGID=xxxxxx ASSIGNMENTOPTIONS="--grant-easy-access --alias %COMPUTERNAME% --group-id Helpdesk --reassign" IMPORTREGFILE=1
But I can still do everything on the PC where I installed the host eg shut down host while I have it blocked
How can I fix this in version 15
Hi thanks for your answer I did indeed not have the Teamviewer_Settings.tvopt in the same folder.
I have now done this and run into the following error message : the use of importregfile=0/1 is decrapted the support of this propertywil dropped soon pleas specify the full path to the setting file with SETTINGFILE
So I changed the command line to the following but then nothing is executed
Command : msiexec /i "TeamViewer_Host.msi" /qn APITOKEN=xxxxxxxxxxxxxxx CUSTOMCONFIGID=xxxxxxxxxx ASSIGNMENTOPTIONS="--grant-easy-access --alias %COMPUTERNAME% --group-id Helpdesk --reassign" SETTINGFILE=Teamviewer_Settings.tvopt
What am I doing wrong ?
I just saw that you have used:
instead of:
SETTINGSFILE=Teamviewer_Settings.tvopt
(the S in SETTINGSFILE is missing)
I'd recommend testing it again. 🙂
I have change the command line and the installation start but then i get the following error Error25010: the source file could not be read
For testing i have make a new tvopt file and i have a new msi file but still i get this message
And when i use the command line with the import rule IMPORTREGFILE=1 then its working and i see the computername in the teamviewer portal **bleep** xxxx$
Thats a littlebit weard because i mace the command line with %username% but still i get computername ....
Anyway can you help me with the error ?
Yes i am very sure i send you a picture with the file name
All right. Thank you for checking.
Could you please test with the following script:
msiexec.exe /i "Path\To\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=YOURIDCCODE ping -n 31 127.0.0.1>nul Path\To\TeamViewer.exe assign --api-token YOURTOKEN --grant-easy-access
and send me back what it looks like in your Terminal so I can check.
When i do this its working for the install
but i have not all the settings ..... that i have defind on the guideline policy
And white this script he add not the device/username in to the teamviewer management console
And white the file that i created before i get the policy and he put the device/username to the teamviewer management console
So i prefere te reg fil ......
Have you any update ?
Sorry for the late answer, @LeoBrons.
It's difficult to say why it is not working.
I recommend opening a ticket so our engineers can have a deeper look at it:
Open a ticket
I use the following script all the time...
msiexec.exe /i "\\SharePath\Teamviewer Host\TeamViewer_Host.msi" /qn APITOKEN=MyToken CUSTOMCONFIGID=MyConfig SETTINGSFILE="\\SharePath\Teamviewer Host\Teamviewer_Config.tvopt" ASSIGNMENTOPTIONS="--alias %username% --grant-easy-access --group ""Computer Group Name""" DESKTOPSHORTCUTS=0
I put that in a batch file in the same directory as the TeamViewer_Host.msi installer and the Teamviewer_Config.tvopt options file. Run it as admin as needed. It is a silent install, applies my custom host settings for logo & colors, applies my client options like no shutdown, allow list, etc, no desktop shortcut, and then puts it in the group that I want with their username.
3
