Operating system: Windows
Version: 15.28.9
Release date: 2022-04-06
We're now switching to the product of a different vendor. It's always one step forward and two backwards with TeamViewer.
Still waiting for a fix when connecting to Lan Only devices when using the "Enter Partner ID" entry box at the top of the TeamViewer window.
To reproduce the issue connect to a Lan Only (Accept Exclusively) computer using the Enter Partner ID entry box at the top of TeamViewer. The first time I connect it works. Future attempts, the Connect button doesn't do anything and pressing enter does not work as well. The workaround I have found is to delete the device from the drop down history list, and then I can connect again one time.
