[Windows] v15.27.3
Justin
edited December 2022 in TeamViewer Remote
Operating system: Windows
Version: 15.27.3
Release date: 2022-02-22
New Feature
  • The session quality setting is now saved individually to the properties of each device or partner in the Computer & Contacts list
  • New remote session windows now open their previous positions on your screen
Bugfixes
  • Changed the location of the crash dump file
German Community Moderator
  • Omar-Os
    Omar-Os Posts: 9 ✭✭
    edited February 2022
    When are we getting the ability to upgrade from 32-Bit to 64-Bit like any other software??
    It's crucial that we can just install 64-bit over 32-bit which should just upgrade fine!
    Uninstalling 32-bit and installing 64-bit manually on thousands of machines in just 1 company is just not funny... or professional..
  • Omar-Os
    Omar-Os Posts: 9 ✭✭
  • LeffeH
    LeffeH Posts: 13 ✭✭
    "New remote session windows now open their previous positions on your screen"
    No, they don't. EVERY window opens up at the LATEST closed windows position and SIZE meaning that I have to resize EVERY newly opened window if the resolution is different than the latest one. This is not funny and NOT a new feature rather a nasty BUG.
  • ilee
    ilee Posts: 28 ✭✭
    This function is too difficult to use, I hope to restore the previous
    Hello all,
    To return to the way it worked before, you need to disable the setting in the options as shown below:
    Hope this could help.
    /JeanK
