Update.exe Blocked; Invalid Signature
I have a fleet of machines running version 15.2.2756 of the TeamViewer application. When attempting to update to 15.31.5 the executable is blocked, flagged as not having a valid signature. The units I'm working with currently are in staging so no AV has been set up and we have Windows Defender disabled to prevent it blocking some of our staging scripts, so I'm kind of at a loss. Has anyone else run into this, and if so, have you found a way to resolve this? Let me know.
Thank you,
nbat92
  • JoshP
    JoshP Posts: 905 Senior Moderator
    Hello @nbat92
    Thank you for your post, and welcome to the TeamViewer community!
    Thanks for letting us know as well - I have reported this internally.
    As soon as I have more information, I will reply again here.
    Thanks again!
    Josh P.
    Senior Community Moderator
  • JoshP
    Hello @nbat92
    Thank you for your patience.
    Our team would like a little more information regarding the devices affected, to assist in investigation.
    Could you please let us know the specific OS version of the devices affected?
    Could you please let us know if the affected devices are missing any important OS updates?
    Thanks in advance!
    Josh P.
  • nbat92
    nbat92 Posts: 2
    Hi Josh,
    We currently support Windows 10 Enterprise LTSC version 1809, build number 17763.2237. If you'd like I'll pull whatever certificate information I can to help get to the bottom of this. All devices I've encountered this on have been from the 28th on and report that the digital signature certificate is "not valid for the requested usage". If there's anything else you'd like me to try I'll do what I can.
    Thank you,
    nbat92
  • JoshP
    Thanks for the quick reply!
    I've forwarded this information, and will let you know if we need any further info.
    As earlier, I will update this thread as well once resolved.
    Thanks again!
    Josh P.
  • I'm experiencing this as well. Windows 11 21H2, fully patched, no AV. Moving from Teamviewer 15.18.5
  • Windows 11 Enterprise 21H2 Build 22000.675
  • Kristian_C1
    Kristian_C1 Posts: 2
    edited July 2022
    Same problem on win 10 IoT when doing remote update.
    I wonder if the problem is due to 15.2.2756 or 15.31.5?
    I hope this can be solved before we have to update Teamviewer on 500+ pc's on trucks scattered over Scandinavia.
  • JoshP
    Hello @MAS_GlendaleAZ & @Kristian_C1
    Thank you for the additional information.
    I have forwarded this information internally as well - the investigation for an overall resolution is in progress.
    I will update you all in this thread as soon as I can.
    Thanks for your help, understanding, and your patience.
    Josh P.
  • JoshP
    Hello all,
    Thank you for your patience in this matter.
    Our development team is still investigating the issue, but has provided a current resolution to allow the updating of the affected devices.
    The issue appears to stem from a specific root certificate; a similar issue was found with some other software as well:
    As mentioned in the above article:
    All public Certificate Authorities, including DigiCert are deprecating older root CA certificates to be compliant with evolving industry standards like Certification Authority Browser Forum.
    Therefore, if the correct certificate are updated, the installations should go through with no issue. The above article provides some methods of deployment for this specific certificate.
    Please find below Microsoft's instructions as well for mass deployment updates of certificates:
    I hope this helps! Please let us know if you have any questions, or should the issue persist.
    Have a great weekend 🌴
    Josh P.
  • thecomputerpeeps
    thecomputerpeeps Posts: 3
    edited July 2022
    Any update on this issue? Thus far, there are two constants:
    • This issue only happens when deploying TeamViewer on a remote system via Files & Extras -> Install -> Install default TeamViewer.
    • This issue only happens on new Windows 11 Professional stations.
    This still appears to be an outstanding issue as of today, 7/19/2022. v15.31.5 for TeamViewer on our station.
    Previous versions of TeamViewer do not appear to exhibit this issue, nor do versions of Windows other than Windows 11.
    UTA 7/19/2022 @ 2:58 PM Eastern -- Deploying via QuickStart on a Windows 10 Professional system exhibits the same issue. Looks like TeamViewer development has identified the issue, but I wanted to UTA Windows 10.
    UTA 7/19/2022 @ 3:05 PM Eastern -- Updating to add what the workaround is. The issue exists in the portable .exe -- a.k.a QuickStart. If you're able to access the system remotely via another tool, installing the standard TeamViewer_Setup.exe allows configuration of TeamViewer for unattended access.
