Cannot change screen resolution
I cannot change the resolution of the Teamviewer session and it remains on 1024x768.
I am using Windows 10 and latest TeamViewer on both server and client.
RDP is available on the server and I can connect, screen resolution is 1920x1080.
There is no monitor attached to the server PC.
I can find the following items in Teamviewer logs when trying to change the resolution:
2022/02/23 09:41:33.685 9052 10128 D1  DisplayQuality m=0, bpp=32, q=80, echo=-1, conRating=2, cpu=28080, capacity=320126, RTT=48819, reliability=Poor, disable animation=1 remove wallpaper=1
2022/02/23 09:41:33.735 9052 11664 D1  Change screen resolution to 1680X1050 failed with DISP_CHANGE_FAILED!
2022/02/23 09:41:33.736 9052 11956 D1  GuiWindowCheckBase::CheckForValidGUIWindows() ok
2022/02/23 09:41:33.761 9052 1052 D1  CGrabMethodDuplication::Initialize() m_State=1
2022/02/23 09:41:33.887 9052 1052 D1!! CDuplicateMonitor::UpdateMovedRects(): GetMovedRects() failed with 887a0026
2022/02/23 09:41:33.887 9052 1052 D1!! CDuplicateMonitor::UpdateDirtyRects(): GetFrameDirtyRects() failed with 887a0026
    JeanK Posts: 7,080 Community Manager 🌍
    Hello @dmezei,
    You can now define the window size, as well as the remote screen resolution. This might help you to fix this issue.
    Please find how to proceed here:
    📄 Fix size and resolution issues
    Hope this will help!
    /JeanK
  • David_Style
    David_Style Posts: 1
    edited August 2022
    I have the same problem.
    I connect, use the toolbar to change the screen resolution, but it remains at 1024 x 768.
    I go into windows control panel and try to change it there, but it still stays at 1024 x 768
    While On teamviewer, I can RDP to the remote computer and change the screen resolution, and it works and shows in TeamViewer at the higher resolution, but when I disconnect the RDP, it goes back to 1024 x 768.
    @JeanK I am not talking of 1024 x 768 as just the default on connection, The computer will not allow any other Screen resoultion than 1024 x 768 with Just TeamViewer connected.
    This is just since the last update, previously I could select and see any higher resolution when using TeamViewer.
  • DNLS
    DNLS Posts: 14
    Hi @David_Style
    I am experiencing the same or similar issue as you. Please see the thread here:
    I have not found a solution yet, but I am working with a moderator to get it resolved. Please follow that thread for updates.
  • I have the same problem as dmezei, any solution?
  • I have the same problem on physical PC. Funny enough windows 10 VM running on proxmox is lettig me change it no problem.
    it's stuck on 1024 I tried methods from above link, same problem won't change the resolution.
  • dmezei
    dmezei Posts: 2
    Thanks, it is working fine for me!
  • Thank you so much. I've been messing around with a second computer and don't have another monitor for it and it has been driving me crazy looking at a little square screen. Thanks!
  • smells
    smells Posts: 1
    edited December 2024
    I am on MacOS and I don't have advanced properties, so I guess I have to code stuff for a software that costs me [removed per
    Community Guidelines] euros a year myself. I'm kind of frustrated by this, rightfully so, in case you didn't catch.
    I've made a PowerShell script to easily change the resolution, it will go through all virtual displays and set them all to 1920x1080
    Open PowerShell-ISE as Admin and press play or run the .ps1 file with Powershell as admin.
    Log-off to apply.
    You may change to the desired Resolution changing the Target Resolution Values:
    # Target resolution
    $targetWidth = 1920
    $targetHeight = 1080
    you can go back to the "optimal" 2004 resolution by selecting it under:
    View → screen resolution → Optimal resolution
    # Define the registry base path
    $registryPath = "HKLM:\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Configuration"
    # Target resolution
    $targetWidth = 1920
    # Fetch all subkeys under the registry path
    $subKeys = Get-ChildItem -Path $registryPath
    # Loop through each subkey
    foreach ($subKey in $subKeys) {
        $subKeyPath = $subKey.PSPath
        # Fetch inner '00' subkey
        $innerSubKeys = Get-ChildItem -Path "$subKeyPath\*" | Where-Object { $_.Name -like "*\00" }
        foreach ($innerSubKey in $innerSubKeys) {
            $innerSubKeyPath = $innerSubKey.PSPath
            # Update the required properties
            Set-ItemProperty -Path $innerSubKeyPath -Name "PrimSurfSize.cx" -Value $targetWidth
            Set-ItemProperty -Path $innerSubKeyPath -Name "PrimSurfSize.cy" -Value $targetHeight
            Set-ItemProperty -Path $innerSubKeyPath -Name "ActiveSize.cx" -Value $targetWidth
            Set-ItemProperty -Path $innerSubKeyPath -Name "ActiveSize.cy" -Value $targetHeight
            Set-ItemProperty -Path $innerSubKeyPath -Name "DwmClipBox.right" -Value $targetWidth
            Set-ItemProperty -Path $innerSubKeyPath -Name "DwmClipBox.bottom" -Value $targetHeight
            Write-Host "Updated resolution for $innerSubKeyPath to ${targetWidth}x${targetHeight}"
  • Thank You, Thank You & Thank You
    I am tired of messing with those little dongles that only work sometimes. So far this has worked on all the Windows machines we have tried.
