PC controlling Android WITHOUT manual authorization?
Syton
Syton Posts: 1
Hello. I'm using a free license for personal use.
My PC is already assigned and set for easy access from my Android smartphone. The mobile device got Host already installed and assigned to my account.
Now I need to connect the opposite way, meaning from the PC to the Android smartphone, BUT without having to authorize the access by pressing "confirm" on the touchscreen.
Is it possible to permanently avoid the manual authorization?
  • JenW
    JenW Posts: 979 Moderator
    Hi @Syton,
    Welcome to our Community! 🤩
    Some of Android mobile devices have their proper addon (according to the device/manufacturer). You can then set up unattended access and connect to the device directly, without any prompts to confirm.
    However, in your case, it seems that there is no dedicated addon for your remote Android device. That means you will have to authorize the connection each time, and confirm manually on the device itself.
    You can find more information about the supported manufacturers in our article: 👉 Supported manufacturers for remotely controlling Android devices.
    Let us know if you have further question, we'll be glad to assist you,
    Jen
