First connection closes improperly. Successive connections are therefore impossible. [v15.33.7]
Marcel_E
Marcel_E Posts: 1
edited August 2022 in Linux only
I'm using TeamViewer 15.33.7 on a Ubuntu 22.04 machine. Whenever I restart the machine I can connect to it exactly once. Closing the connection leads to an error regarding an invalid window parameter (see screenshot). This leaves the TeamViewer process in a weird state: Not fully crashed but also unable to accept any further connection until the machine is restarted. Nothing less than a full restart seems to fix the issue (e.g. stopping and restarting the service).
This problem persists for at least 3 months now and I'm getting increasingly desperate.
Does anyone have an idea how to approach this problem? I am not even sure what the root cause might be... Is it related to X.org?
Thanks for your help.
Marcel
[removed per Community Guidelines]
  • Nanco
    Nanco Posts: 1 Newbie
    Me too.
    Help.
  • ICNS
    ICNS Posts: 1 Newbie
    edited September 2022
    Exactly the same problem here.
    Help...
  • misterm3140
    misterm3140 Posts: 4 ✭✭
    I figured this out by downgrading to 15.1.3937.
    I was experiencing the same issues.
    First use:
    apt-cache showpkg teamviewer # Check to see if you have 15.1.3937
    Then use:
    sudo apt-get install teamviewer=15.1.3937 # Downgrade to this TeamViewer version
