TeamViewer only connects once, then have to restart the computer to connect again
I have TeamViewer version 15.33.7 (I have tried other older versions but still have the same issue) for Ubuntu 20.04 and I can only seem to connect to the computer once before I am stuck in "connecting" when I try to connect once more.
The only way I can seem to connect again is by completely restarting my computer. I was wondering if anyone has had this issue before.
  • misterm3140
    misterm3140 Posts: 4 ✭✭
    I figured this out by downgrading to 15.1.3937.
    I was experiencing the same issues.
    First use:
    apt-cache showpkg teamviewer # Check to see if you have 15.1.3937
    Then use:
    sudo apt-get install teamviewer=15.1.3937 # Downgrade to this TeamViewer version
