TeamViewer incoming connection issues
rad82cornell_edu
rad82cornell_edu Posts: 1
edited September 2022 in Linux only
I have a new computer (named AMD1) I've added TeamViewer to, and I'm having the following issue.
I can connect from AMD1 to any other computer with no issues.
I can connect to AMD1 from any computer once. If I close the connection and then try to connect to AMD1 again, the connection fails. I have to restart the computer before I can connect to AMD1 again. Restarting TeamViewer does not fix the issue. A computer restart is required.
I have had all computers with TeamViewer re-listed as non-commercial use devices.
I have rebooted AMD1 into both Wayland and x11. The problem is the same for both.
I have opened the recommended ports on AMD1 per the TeamViewer recommendations.
I have gone through every iteration of whitelisting and related connection settings in the TeamViewer GUI that I can think of.
I have uninstalled and reinstalled TeamViewer multiple times using all installation methods.
I am able to ssh into AMD1 with no issues.
Summary: It looks like after one successful connection, AMD1 blocks all additional incoming TeamViewer connections until a hard restart is executed.
Has anyone encountered this scenario or have any idea what I could try next to resolve it?
AMD1 information:
Ubuntu 20.04.4 LTS
Processor: AMD EPYC 7713P 64-Core Processor
GPU: NVIDA RTX A5000, CUDA Version 11.7
  • misterm3140
    misterm3140 Posts: 4 ✭✭
    I was having the same issue as you, but I resolved the issue by downgrading to 15.1.3937
    First use:
    apt-cache showpkg teamviewer # Check to see if you have 15.1.3937
    Then use:
    sudo apt-get install teamviewer=15.1.3937 # Downgrade to this TeamViewer version
