On Debian 11 cannot connect after logout/restart
Palmi
Palmi Posts: 2 ✭✭
Hello Everybody,
I installed Teamviewer 15.34.4 (free version) on a PC with Debian 11. Even if I configured "Start TeamViewer with system" and "Grant Easy Access" to connect from remote I need to log the system via other ways (RDP) and launch TeamViewer from menu, but if I restart the system or log-out I loose any possibility to connect again with TeamViewer.
Of course I run "sudo systemctl start teamviewerd" and "sudo systemctl enable teamviewerd", but seems not changing anything.
Is there, maybe, any piece of previous installations that is preventing the normal behaviour?
I re-installed (purging the previous installations) several times, but unsuccessfully.
I thank you in advance for any hints on how to solve this problem
Best regards
Dario
  • Palmi
    Palmi Posts: 2 ✭✭
    I solved my problem updating the client to the latest version.
    Thanks anyway
    Best regards
    Dario
