It appears to have fixed itself, thinking it was a poor web connection.
I have the same issue. It think my access is commercial. Granted it's running on a commercial facility of the Salvation Army. I'm running an Emergency Disaster Service Winlink Gateway. The facility is 60-plus miles. I remote to quickly monitor the system's running.
It's an Amateur Radio Email program that we use if we lose the internet. Unfortunately, it shuts down. I had this issue years ago and I explain it was not for profit or commercial access. It's frustrating to have to drive 60 miles to work on the PC when I can log in.
Don
Remote Sysop
va7tsa
Salvation Army Emergency Disaster BC Division
Radio Manager
Hi @DMRCPA,
Thank you for visiting TeamViewer Community!
When the connection cut off, did you see any error message from TeamViewer? What did it say?
Meanwhile, may I ask you kindly try to restart TeamViewer services on both sides and then try again for the connections?
Keep me posted about your progress.
My system only stays connected for 19 seconds. Then punts me out. Is that a system error or web issue?
Dennis
