Where I can find vendorexampleapp c# source code
Hi, where I can find vendorexampleapp c# source code (Remote Access API Integration Guide - TeamViewer Support) to start integrate my application with TeamViewer?
I want integrate a simple button with start remote connection from my application.
Daniele
Hi, guys.
Same situation here. We would like to integrate TeamViewer into our system, and we would appreciate if we can get access to the source of the VendorExampleApp. Also, it would be nice if documentation for REACH API related to responses from your side (structure, data types and etc.) can be improved.
Thanks in advance,
Srdjan
Is there an update on this? I'd like to test out the VendorExampleApp for my Android integration.
Hello everyone,
I'm also looking for the VendorExampleApp source. Could you provide a link to have a better understanding of the Remote Access API Integration Guide - TeamViewer Support please?
The api documentation is not aligned with examples (eg: "request_id" format).
Thank you for you help.
