Hi there, I'm planning to buy license for 1 year for remote access, as I'm travelling a lot is my license will be working to provide remote access even I'm not on my main country?
Hi @Vieirinha,
Thank you for visiting the TeamViewer Community!
The TeamViewer license allows you to connect to the devices you like when you are onboard. I would recommend you contact our License specialist for a detailed discussion and find the best-fit license option to suit your use case.
Happy Connections!
