How to change language in the latest teamviewer?
I googled around but the solution provides by your website is either outdated (the interface changed since then) or there is something wrong with my version
I use windows 10 latest update and TeamViewer 15.40.8 there is nothing in the settings / advanced tab for changing language...
  • Ying_Q
    Ying_Q Posts: 2,597 Moderator
    Hi @Sokratis199,
    Welcome to the Community!
    The language option is also available on TeamViewer v15.40.8. Kindly check the screenshot and follow the steps to find the language option.
    If the steps if not clear to follow, I have also listed the path:
    1. GearWheel (⚙) from the top right corner of the TeamViewer client;
    2. Advanced on the bottom list of TeamViewer options;
    3. General advanced settings then Display language, and pick your preferred language option.
    I really hope the explanation information would be helpful to locate the language option.
    Let me know if you would any more information about this setting.
    Community Moderator/中文社区管理员
  • jaknudsen
    jaknudsen Posts: 2
    how do I change language in TeamViewer v15.52.3 on macOS?
