Please can you add in a setting so that the position of the toolbar can be moved anywhere on the top edge of the screen. Doesn't have to be fancy... maybe a NumericUpDown running off of a screen width percentage.
Or even the ability to move it to the side.
Or better yet being able to completely disable it and move the buttons to the windows aero popup on the taskbar or on a right click of the taskbar icons / tray icons etc.
It gets in the way even when collapsed.
Much appreciated
