Remote desk iPhone
Kingstach5
Kingstach5 Posts: 1
I want to remotely view an iPhone with an Android phone. To connect between two Androids, it was enough to install Teamviewer Host on one of the phones and everything worked fine. There is no Host for iOS, so how to do it?
  • JoshP
    JoshP Posts: 895 Community Manager 🌍
    Hello @Kingstach5
    Thank you for your post, and welcome to the TeamViewer community!
    There is no Host app for iOS as it is not possible to connect to an unattended iOS device; therefore, you will want to use the Quicksupport app for iOS on the device you wish to connect to:
    I hope this helps! If you have any other questions don't hesitate to ask.
    Josh P.
    Senior Community Moderator
