[Windows] v15.46.5
JenW
JenW Posts: 997 Moderator
edited October 2023 in TeamViewer Remote
Operating system: Windows
Version: 15.46.5
Release date: 2023-09-26
New features
  • It is now possible to move devices to groups and assign policies directly to them, or, inherit a policy from the group to which they are moved.
Improvements
  • Any changes to device list sorting and column-width are now saved after re-opening the client.
Bugfixes
  • Fixed a bug in device groups that could prevent options from working after right-clicking on a device name.
  • Fixed a bug that caused double ellipsis buttons to appear on the device group list entries.
  • Fixed a bug that prevented the comment function from working within a session.
  • Fixed a bug that could prevent a user from installing a custom host on the remote side during a session.
  • Fixed a bug that caused the TeamViewer login screen to stay blank after a Windows restart is interrupted.
Modératrice Communauté Francophone / French Community Moderator
