[Android] Host v15.46.304
JenW
JenW Posts: 997 Moderator
Operating system: Android
Version: 15.46.304
Release date: 2023-10-11
Bugfixes
  • Preventative update of the libcurl dependency.
  • Minor fixes and Improvements.
Modératrice Communauté Francophone / French Community Moderator
  • LuisaSpagnoli
    after upgrading android to v 13 the app quicksupport on LENOVO TAB m10 does not allow us to click on apps and remote control. The result is like a continuous long press on each app and the longpress menu showing up.
    Please upgrade the add-on for lenovo asap
  • AMcG
    AMcG Posts: 1
    I have the same problem. Two weeks and no reply from Teamviewer :(
  • loadamasta
    loadamasta Posts: 1
    I have the same issue. With this problem, Teamviewer is useless for all Lenovo Android devices.
  • JenW
    Hi @LuisaSpagnoli, @AMcG & @loadamasta,
    We thank you all for sharing your issue with us, and we apologize for the inconvenience.
    Please know that this issue has been forwarded to the respective team. They are currently working on it, and we kindly ask you to be patient in that matter.
    Rest assured that we will update you as soon as we have more information.
    Thank you for your understanding!
    Jen
