[Windows] v15.48.4
JenW
JenW Posts: 987 Moderator
Operating system: Windows
Version: 15.48.4
Release date: 2023-11-21
Improvements
  • Groups are now displayed in alphabetical order in the modals where users add, move, or remove devices to and from groups.
Bugfixes
  • Fixed a bug in the device list that prevented showing the correct tooltip for the Connect button.
  • gayed
    gayed Posts: 1
    thanks very
  • tvusher
    tvusher Posts: 5 ✭✭
    Question: Where to download it since links on site are for .47.x? Also when checking TV's updates it says no new updates available.
  • BOOOOOOOOBOOOOO
    BOOOOOOOOBOOOOO Posts: 2 ✭✭
    There are a lot of bugs
    VPN ip The content of the chat window cannot be copied
  • fwone_yb
    fwone_yb Posts: 2 ✭✭
    Automatic recording of remote control sessions is disabled after updating. Even if this feature is checked, recording still needs to be started manually after each remote connection is established. In addition, the new version still cannot use Chinese input.
  • hrh747
    hrh747 Posts: 4 ✭✭
    Would you happen to know whom I need to talk to about not being able to sign into the TeamViewer app on the Windows 11 desktop? The ID field doesn't allow us to enter ID, and when it does, the sign-in button doesn't activate.
  • tvusher
    tvusher Posts: 5 ✭✭
    By becoming paying customer. Forums are quite waste of time.
