"Master" Whitelist not so master
I have over 4000 endpoints and dozens of IT and helpdesk personel that I want to Whitelist. I want to divide these enpoints into 5 or 6 different security policies. To me a Master whitelist would be a list created based on established users in admin console and then applied to different policies... I hope I am wrong but it appears that i have to manually create a seperate Whitelist for every single security policy manually and then maintain all 6 whitelist everytime we hire or fire someone.
Lee
Hi lross78550,
Thanks for posting!
Unfortunately there is no way to create a master whitelist that is the same accross multiple policies and this is currently in as a feature request.
However, if you want to grant access to all users in your company profile, you can add your company to the whitelist and then anyone currently in the company profile will be whitelisted.
Also, I have changed your avatar to the fox, you can change these under your profile settings, just click your avatar and select from the community options.
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?5
Why the **bleep** did I get assigned the Pink Pig avatar?
Hi lross78550,
Thanks for posting!
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?5 -
THanks Scotty
