Newb: Deploying TeamViewer Host on MacOS Using Intune
I am having trouble finding accurate information on how to use Intune to Deploy TeamViewer Host. I have a script that downloads the Custom PKG file. And can deploy this using Intune. My issue is finding accurate information on Setting the configuration and allowing Full Disk Access using Intune. Can anyone point me in the right direction?
  • JenW
    JenW Posts: 997 Moderator
    Hi @dbarker12,
    We're happy to welcome you to our Community! 😃
    Did you have the chance to take a look at our dedicated article? If not, please check it out with the link below:
    📄 Intune Integration - Installation and User Guide
    You'll find information about the deployment of TeamViewer via Intune with helpful screenshots!
    In case you're stuggling for a specific step, please come back to us and we will guide you further.
    Jen
    Modératrice Communauté Francophone / French Community Moderator
