Linux version does not start automatically
jun605x
jun605x Posts: 5 ✭✭
Today, I updated the Linux version with sudo update, and now it does not auto-start.
To be precise, it starts once at system startup, but then immediately crashes.
When I try to start TeamViewer again from the launcher, I get a message that the daemon is not running and that I should run "teamviewer --daemon start".
After executing the command, TeamViewer starts, but it crashes after rebooting.
The option "Start at system startup" is on.
Any advice?
  • jun605x
    jun605x Posts: 5 ✭✭
    Thank you.
    I have now started the calculation of my work, so I will try to do it later!
  • r8d_engr
    r8d_engr Posts: 1
    edited April 17
    The same issue we are encountering, needs to start or enable the daemon, because after every reboot, it failed to start. Running into Ubuntu 20.04.6 LTS
    Please start the daemon (needs root permission) before running TeamViewer:
    teamviewer–daemon start
