Remote connection works fine and then "Authentication Rejected"
As in title. This is very frustrating. I don't have any other information than 1. it works, and then 2. the next time I tried to sign-in it gives me the "Authentication Rejected" error message.
The first time it happened, I was at home and could reboot. Now I am away, and needing to access my home computer, but I can't.
I have read some other forum posts, and it seems other people are having the same issue.
Is there a solution?
  • iainwels
    iainwels Posts: 121 ✭✭
    Hello TheCnidocyte,
    Does your home computer have a password? If it has try putting it here (look at my guide). It could be that the authorisation thinks that you are not putting a password in and it just wants to connect without a password.
    1. Go to your pc that says authentication fail. 2. Go to the Settings symbol. 3. Go to properties1. Go to your pc that says authentication fail. 2. Go to the Settings symbol. 3. Go to properties4. Add your password here4. Add your password here
    Iain Wels,
    ICT-Support
