In TeamViewer, there is an option called "Permission Inheritance".
But it is set to no.
How can I activate it?
Hi @bcatoe,
Thank you for reaching out!
You can now apply the permissions at the group level instead of setting the permissions for each device.
Please find how to proceed here: Apply manager permissions at group level
/JeanK
@JeanK hello again. It has been 3 months since my follow up. Is there any timeframe from Dev on when they will make group permissions work properly? It makes no sense at all that when we add someone to an existing group we then have to go add them to each and every computer IN the group. The entire point of being able to assign permissions to a group is to NOT have to do that.
I have already been pushing for our company to look at other solutions. This kind of nonsense issue and the lack of any kind of timely response to fix them is the major reason.
Hi @bastiann,
The team just informed me that the functionality is available. However, there are some bugs preventing it from working as expected.
The team is currently working on a solution.
I'll inform you when it's fixed!
Is there an update on when this will be fixed, or even acknowledgement from DEV that they have confirmed the problem?
@bcatoe thank you for the extra information. I connected with our product team to ask about the current status; I will let you know as soon as I get an answer.
@JeanK it appears that NEW computers added to a group do inherit but a change to the group does not get pushed to the existing computers. For example, if I add a new manager to an existing group and give him group manager rights…he cannot rename computers that were already in the group. He can rename new computers that get added after him.
Thank you for your engagement in this thread.
I'll reach out to the dedicated team and see if there's something we missed here.
I'll get back to you as soon as I have news to share.
@Moderator @JeanKBusiness I'm not seeing any replies to my updates in this thread. The Easy Access permission does seem to inherit to the devices in a group but Group Admin rights do NOT inherit. This is a basic function and needs to be fixed. We should not have to set permissions to each device in a group.
@Moderator
Is this thread still active?
inherited permissions still do not work. We have a group with 30 devices in it. I add a manager to that group and give him "group admin" rights. That person does not have the ability to rename the devices in the group. When can we expect this to be resolved?
We DO have it enabled
they still do not work
to be clear, we DO have this setting enabled but it still does not work
@JeanK inherited permissions still do not work. We have a group with 30 devices in it. I add a manager to that group and give him "group admin" rights. That person does not have the ability to rename the devices in the group. When can we expect this to be resolved?
Hi, the issue with the inherited group permissions is still there on Android devices.
If the permissions are inherited, I can't connect to Android devices (the connect button is not there any more, just a small blue cube?):
If I add me manually as a manager on the device, The connect button is there and works.
@Anthony014, I just spoke with the dev team and I can confirm that the issue has been resolved.
Is everything working as expected now on your side?
Dear JeanK,
Any update on this issue ?
Permission have been assign on the Device Group level but no technician can use Easy Access on existing device or new.
Thank you,
I just learned that it's not yet working if you activate Easy access on the group level for user groups. It will be fixed by the end of this month.
In the meantime, assigning the group to single users should work fine. Can you confirm on your side?
Hi @JeanK, unfortunately the Easy Access in the device menu is also not working :(
This is the permission at group level:
And this on the device level (since the permissions are inherited):
As you can see, Easy Access is greyed out (but if I click on TeamViewer Password, I can connect to the device without a password?):
Another thing I noticed after enabling the Inherited Permissions and removing a single assigned user from the device is that the TeamViewer Host itself does not show as "managed by Company name" anymore. Instead, the following message is shown (even tough the device is correctly registered in our TeamViewer tenant). That is just a cosmetic error, but it irritates our users since they think they need to register something.
This is my TeamViewer Client version: 15.59.3
Thanks!
@bastiann I just synced with the dev team, and I can confirm that this is a current bug our team will fix soon.
Currently, even though the Easy access permission has been granted on group level, the Easy access permission is not recognized in the device dock.
This bug only affects the device dock; therefore, you can connect to the remote device via Easy access via the Devices menu of the client.
I'll update the thread once the fix is deployed.
Sorry for the not-so-good news and for your understanding.
Have a great day!
@bcatoe I just got the info that if you enabled the setting in the web app, you need to restart the client, so the setting gets applied. Does this explain why it wasn't working?
@bcatoe Thanks a lot for reporting this. I'm happy that you could solve the issue in the end. Regarding the inconsistency client/web app, I'll pass this over to the respective team so they can look at it.
@bastiann Let me ask the team and get back to you as soon as I have an update for you. 🙂
@JeanK also, with the inheritance, easy access does not work. In the group the permissions are set, but on the device itself easy access is greyed out…
@JeanK , well, that doesn't seem to work. We did those steps, the user still not inheriting device permission. And now when we click 'add managers' the message says "no assignable users'. So now we can't even add users to groups at all from inside the app but we just figured out we can from the website. This is very inconsistent.
@JeanK Wow, thank you!! 2 of us were banging our heads trying to figure this out.
This is not efficient at all or even logical. Inheritance should be exactly that, meaning permissions should percolate to the devices in the group. At the very least, there should be a 'refresh' option or a listed permission for rename. If I make someone a manager of a group, then I am explicitly choosing to do so. They should then be able to manage the group, meaning the devices IN the group.
As I understand this setup currently. Say I have a group with 50 devices in it and I want the manager of that group to be able to rename them if desired. I can't just give him permissions at the group level. I can't even go to the group, select all of the devices IN that group and then set the permissions. I have to go to the All Devices list, where they might be scattered thru a list of 500 devices, tag them, then set the permission.
Am I wrong?
Hello @bastiann,
Thank you for contacting us; we are thrilled to have you in our Tensor Community!
Permissions are not “inherited,” or at least not all permissions; you can inherit easy access or the permission to apply policies, but if you want to change the name of the device, you have to be the direct manager of the device, and that is not inherited.
So, if that is what you wish to do, please click on the link below, where you will find important information about it:
Understanding how manager permissions work (teamviewer.com)
Please check the article and let us know if you have any further questions. We will be happy to continue assisting you.
Al the best,
Valeria/TeamViewer
Have you heard?! On October 21, we’re hosting TeamViewer Rise—and we want to see you there! The digital event dedicated to IT experts. Join us to hear industry leaders as they share demos, roadmaps, and real-world strategies for delivering better IT. Take part in our first annual event for Proven, ready-to-deploy…
