Is there a way to set the default "Screen Resolution" to "Optimal Resolution"? Either for the entire account or for a specific device?
It seems each time I log into this particular device it goes back to the native screen resolution.
Setup if relevant:
Device connecting to:
Windows
2x 1440p monitors
1x 1080p monitor
Device connecting from:
Windows
1x 1080p monitor
Both on TeamViewer Full Client
Upon connection I change the display from "Extend" to "Pc screen only" which brings the monitors from 3 down to 1 so it is more manageable.
I then change the View - Screen Resolution to "Optimal Resolution" to match.
Thanks!
