Firefox starts, but is only a white box.
When I start Firefox via TeamViewer only a white Box appears. When I click the right locations, it works, but everything is white. Also window titel bar with buttons to hide/minimize/close.
Without TeamViewer Firefox starts normally.
Hardware: HP Z440 WorkStation, Windows 10 Pro, NVIDIA Quadro P4000 (375.86 ISV-certified driver)
Already tried:
- install different graphic drivers
- install different Firefox releases
Thanks!
I reinstalled the NVIDIA-driver on the machine, but not via TeamViewer.
Now the installation looks good and everything works.BR Lukas
5
Did you try to desactivate the graphic acceleration in firefox option?
I have also two quadro in sli, I resolved the problem with firefox but I have the same problem with 3dsmax if I'm using nitrous driver...
5 -
Whenever at least one monitor remains physically connected to the remote host's GPU (HDMI or DisplayPort cable), Firefox renders correctly over TeamViewer. If I disconnect the last monitor cable, the existing Firefox windows are no longer responsive/refreshed and new ones render as white.
This is with most recent Firefox and Nvidia
We have here the same problem with a Lenovo and a Intel HD Graphics 620,
I try from cmd Firefox -save-mode this will work,
but is no soultion because we need the plugins0 -
Had the same issue on Lenovo ThinkPad T440s with Intel HD Graphics 4400
Last night - after installing Windows Feature Experience Pack 120.2212.31.0 the issue "repaired itself" and now FF 79.0 looks as expected
Windows 10 Pro 64-bit
Version 2004
OS build: 19041.450
