kali teamviewer bug?
hello
i'm finding this topic for instal the teamviewer on kali linux on a raspberry pi 3
https://community.teamviewer.com/t5/Linux/Teamviewer-on-Kali-Linux-AMR/td-p/1765
it's ok is installating but when i open the teamviewer i'm nothing ID password and when i clic on option a new windoww open and nothing inside....
please help me
thanks
ps: sory for my english:(
Hello devilhacker,
Could you try to expail it some more (P.S. If you're native language is Dutch, French, German or Spanish, Spanish is my worst spoken language, Private message me!!!). I am so sorry but i could not understand you,
I hope this helps,
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people0 -
I instal the teamviewer but I have this https://images.imgbox.com/42/9b/pCUBcs7z_o.jpg wat is the problem. Internet ok.0
no answer?
Dear devilhacker,
Thank you for your post and screenshot provided.
This looks like you have missing dependencies make sure you have the following dependencies satisfied:
- libc6 (>= 2.17),
- libdbus-1-3, libqt5gui5 (>= 5.2.1),
- libqt5widgets5 (>= 5.2.1),
- libqt5qml5 (>= 5.2.1),
- libqt5quick5 (>= 5.2.1),
- libqt5webkit5 (>= 5.1.1),
- libqt5x11extras5 (>= 5.2.1),
- qtdeclarative5-qtquick2-plugin (>= 5.2.1) | qml-module-qtquick2 (>= 5.2.1),
- qtdeclarative5-controls-plugin (>= 5.2.1) | qml-module-qtquick-controls (>= 5.2.1),
- qtdeclarative5-dialogs-plugin (>= 5.2.1) | qml-module-qtquick-dialogs (>= 5.2.1),
- qtdeclarative5-window-plugin (>= 5.2.1) | qml-module-qtquick-window2 (>= 5.2.1),
- qtdeclarative5-quicklayouts-plugin (>= 5.2.1) | qml-module-qtquick-layouts (>= 5.2.1)
Recommended packages:
- ttf-liberation | fonts-liberation
You can do an 'apt-get install package1, package2,..., packageN' to install them.
Once everything is installed, please restart TeamViewer by running the following command
sudo teamviewer daemon restart
Hope this solution works for you.
Christian
Did my reply answer your question? Accept it as a solution to help others, Thanks.1
