I have 5 unknown connections in my TV that I would like to remove. They are probably old computers over the years. How do I remove them if I do not see them in the client. Just on the web and I cannot remove them
As you can see from the picture above, I have 5 old connections that are no longer valid and I am sure these were computers that I have reloaded at some point over the years. But I do not want them in the lists and I cannot find them anywhere to remove them. Looked in the registry and still nothing. I think they need to be removed from TV side
Hello @KCofIndy,
Thank you for the screenshot.
At the moment, removing devices from the list of recent connections is impossible.
As you connect with other devices or session codes, the old devices will gradually be removed from your recent connection list.
However, while searching, we found other users in our Ideas Hub who wished for the implementation of the same feature. You can upvote here.
We can't guarantee that all ideas will be implemented for future versions, but this is the best way to communicate with our development teams about desired changes.
Feel free to reach out if you need any more assistance.
Valeria
To understand your case better, please send us a screenshot in order to give you the right assistance.
Looking forward to hearing from you.
