How do I set up my home pc so I can access it remotely?
So this is no longer available on free accounts ie: EASY ACCESS?
Hi @wcndave ,
Thank you for visiting TeamViewer Communityš
Are you referring to the section titled āIf the TeamViewer full client is installedā, specifically the part about how to "manage this device" in the article below?
Provide unattended remote support
If so, that guidance is designed for situations where you're currently on the TeamViewer account login page. If you're using the new interface, it should resemble the image shown below, and you can follow steps 1 to 3 in the picture to find "Manage this device" menu. You can also access these settings after logging into your Full Client account by navigating to the Advanced Settings menu (If you'd like us to walk you through the steps in detail, just let us knowāweāre happy to help! š)
Noteš”: You need to have administrative rights to manage your device.
If you were referring to something else, please feel free to reach out with any questions. We're always happy to help! š
Chisa
just like to say that the instructions on that article are incorrect.
If you go to general under settings, there is no "manage this device"
Hi @ms1,
Welcome to the TeamViewer Community š
It seems like unattended access can benefit you well from your description, so I'll walk you through how to set up unattended access, which allows you to connect without needing someone physically present at your home computer.
šBefore you begin, please make sure that the operating systems on both of your devices are supported by TeamViewer: Supported operating systems for TeamViewer
Hereās the overall setup for configuring unattended access:
Please follow the step-by-step instructions to set up unattended access on your remote device: Provide unattended remote support
Iāve introduced a general method for configuring unattended access. If you need further clarification or have a specific setup in mind, please donāt hesitate to reach outāweāre happy to help!š
