Windows 10 last version 1709 and Teamviewer 12
After closing Teamviewer, this script error appears
What's wrong?
  • iainwels
    iainwels Posts: 121 ✭✭
    Hello jaakpen,
    I have maybe a **bleep** question but is it only when you close teamviewer or also when you open it? And this is a script error so i think its not the teamviewer causing the issue but your computer. You could try redownloading the client and have a look if the scripterror has been fixed!
    I hope this helps,
    Translation error
    Scripterror
    There had been a error in the script of this page.
    Rule: 0
    Symbol: 0
    Error: Script error
    Code: 0
    URL: https://js.usermessages.com/messageswidgetshell.js
    Do you want to go on with the running the scripts on this page?
    Yes/No
    Iain Wels,
    ICT-Support
  • iainwels
    Hello jaakpen,
    Is you're problem solved? Could you look at you're private messages? If you're problem is solved could you explain what solved you're problem so others with the same problem could also be helped?
    Thank you for using teamviewer!
    Iain Wels,
    ICT-Support
  • Sorry, issue is not resolved
    1. The script error occurs whenever team viewer is closed.
    2. I have this script error on all my 3 computers since the new windows 10 update version 1709 of 17/10/2017 - https://support.microsoft.com/en-us/help/4043454
  • Hello guys, you have found solutions regarding https://js.usemessages.com/messageswidgetshell.js
    I tried everything but nothing, do you know if the problem is due to some windows upgrades? I, for the sake of this problem, can not use TeamViewer, if someone has found the solution explains how to do thanks.
