Cross platform ?
I would like to take remote control a Mac. I have a PC under Windows 10. Is it possible? Excuse my English I am French.
Thank you.
  • thank you !
  • Problem accessing Filemaker app from HP Spectre Win 10.  The FM app is on a macOS 10.13.3.  Is there a support page that shows supported OS compatability?
    Remote control from my iPad (IOS 11.2.6) works fine.
    Description of issue.
    Calendar fields configured with an icon to show/hide the calendar. Click icon produces erratic results. Usually just selects the field as if I had clicked in the field and does not display the calendar. Occasionally, clicking the icon will cause the drop-down calendar to appear momentarily only. I’m able to enter keystrokes in the date field as designed.
  • I'm not sure what has changed but I'm no longer seeing this problem.  I did file a report with Teamviewer so perhaps something was changed.  I have been using TV 13 for about a month and have consistently without exception had the issue I reported.  Go figure.  Seems to be no longer an issue.
    Thanks to any of you who spend any time thinking about this.
    Unc
