How to do it TeamViewer to start minimized to the tray automatically (without showing the main window at launch).
I read many post or idea but no solution.
Its possible implement this ?
I request the same. I have Teamviewer automatically starting when starting my computer. Since latest update it suddenly shows the Interface window instead on computer startup. On previous versions it would not do this and startup minimized in the taskbar. Please return this option to automatically start Teamviewer minimized.
Same here, consider allowing us to choose how to start the client in the next version.
Another vote for this.
Eeeh yes, please!
It's the most annoying antipattern to let software services start in the foreground without an option to prevent that.
I want a clean Desktop without any App Windows popping up at startup. Period.
It was possible for years to start teamviewer minimized and it seems now we have to request a new feature to get it working ? I don't understand well what is happening here. It is a basic feature, how comes it's now gone ?
Thank you for all the feedback on this issue!
Please know that we have forwarded the case internally to the designated teams. They are aware of the problem and currently working on it.
We will share the updates with you as soon as we receive further communication.
For the time being, thank you for your patience and understanding.
Elif
Same here on different machines. I would kindly ask you to come back to the previous situation, allowing us to start TV minimized. Cheers.
Same, as this has stopped me even considering a paid subscription anymore, let alone WOL no longer working either. Starting minimized to the system tray used to work, not anymore since the last update.
Install this and disable updates:
https://dl.teamviewer.com/download/version_15x/TeamViewer_Setup_x64_15.69.5.exe
This "feature" of minimizing to systray, has been working for years.. This issue has only arose since the last teamviewer update, PLEASE bring it back.
Starting minimised is exactly what it used to do and is what everyone wants it to do - why would we want it maximised?
It would seem that this is a very widespread problem arising from a recent update, PLEASE can the development team realise that there is an issue and get it sorted.
+1
The old UI had the option, but with the new UI it's no longer available.
I ASSUME this is a programming bug and an urgent patch fix must be imminent. Or a rollback. Please update the community on how long this abomination will persist?
Having only just updated to the latest version it seems retrograde to have to roll back to an earlier version to fix this (?deliberate) feature!
Agreed with all the other comments as my teamviewer updated automatically to the latest version which removed this feature to start minimized/minimised so it does not bother you but can run in the background to allow your remote connections, I have no idea why this was removed and needs to be fixed. At least give the option to select if you want it to run in the foreground but to force it to open maximised isn't right.
I'm so annoyed because I didn't expect it to have auto updated and only now have changed it to not update automatically especially since it was checking for updates weekly as well but I will have to use the link provided to downgrade to the previous version which had this functionality or alternatively use a different program.
