With Teamviewer at a VM controlling the host PC
If i try to connect Teamviewer on my virtual machine and my host PC everything is fine. It works and i can controll my VM with my host but my VM isnt able to controll my host, no matter how i set my settings. Why is it not possible or how should it work ?
  • Chiron
    Chiron Posts: 226 ✭✭
    Ummm.... I can't think of why you would need to do this, but I just tried it and it worked for me.
    How far are you getting? Are you prompted for a password?
    Are you able to connect using an IP instead of the TeamViewer ID?
  • Lasse
    Lasse Posts: 2
    I can verify and i can move the mouse, but i am not able to open a programm or move a window. I can only see and move them mouse.
  • Chiron
    Settings may need to be changed on the remote computer.
    Options > Advanced > Access Control
    Full Access will allow you to control the computer, or you can configure a custom setting.
Howdy, Stranger!
This Week's Leaders
